evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sun Jul 26, 2009 11:20 am
just buy the brackets on ebay, they are lightweight no rusting aluminum and you won't spend 3 hours at the junkyard trying to remove the stub axles to get the brackets off
hsi kit uses the max calipers and s130 rotors but I'm pretty sure you can still use the s130 callipers but the ebtrake cable might require a bit of extension
