l80_240 »
https://forums.nicoclub.com/l80-240-u35367.html
Wed May 21, 2008 1:25 pm
exactly tires make the biggest thing in single braking, larger rotors and bigger calipers only come into play with repeated stopping, although the added torque from larger rotors and calipers can help but they can also cause quicker lock up. Pads and Tires are the things to look at first, and with time will come better selection, the bigger thing is a converion for the rear, the fronts are decent for a stock and mild application but the rears selection and grip for braking is what ive looked into, and if i had the money id say the new sentra with rear disc could be swapped onto the rear of the versa, they share the same beam and hubs, spindles and look very similar. if your having brake problems think what your problem is first then deside what is needed for better braking, and i would not trust KSport for brakes, as they can not build a good coilover. I would go with a set of Hawk HPS pads and new tires...just my .02
