brake upgrade ??????
chaosli
Car: 89 nissan 240sx coupe FTW
99 mazda miata
93 bmw 325i RIP
i was thinking of getting better brakes while i put my 5 lug conversion onjust wondering which is a better choice R33 or 300z TT brakes and whats the difference between them.anothing thing i wanted to ask is do i need a bracket to fit them or they fit on hole where the bracket is suppose to be
sommmatt
Car: 1989 Nissan 240SX
ibtl
chaosli
99 mazda miata
93 bmw 325i RIP
i searched but i didnt find if the skyline brake is the same as 300zx tt brakes i just know they r 30mm
Ali 556
Car: '95 S14 Se....
About the 300zx brakes they are direct bolt on....but you need custom brake lines...
The GT-R Brakes Are Bigger then the Z's and will need brake lines too...
Stock brakes (FRONT) are : 9.8" = 248mm (Singel piston caliper)
Z's Are 11" = 280mm (4 piston caliper)
350Z Are 13" = 330mm And Masssive 4piston caliper (must redril the mounting holes)
EVO IX / STI Brembo Are 320mm = 12.6" And will need adapter plate...
Check here :
http://importnut.net/300zxbrakeswap.htm
Also search on zilvia.net....
IBTL x2
Ali
chaosli
99 mazda miata
93 bmw 325i RIP
thanks for link and i am still kinda new so i dun know alot BTW whats IBTL
heartofaskyline
Car: 1992 hatch, 1993 sr20 coupe
ibtl= in before the lock. basically there saying you didnt search and a mod is gonna come and lock your topic because its retarded. and there right
IBTL
BIGTIMER_240
Car: 1989 240SX ka24de
get the 300zx brakes they are great i have them and for the lines just get the 300zx lines they work
Ali 556
Car: '95 S14 Se....
chaosli wrote:thanks for link and i am still kinda new so i dun know alot BTW whats IBTL
Then SEARCH B4 Posting.....
You Can Do ANY car brakes into S13/S14...
What i've seen so far :
300zx brakes (easyest route)350Z Brakes (Will cost you around 1000-1200$)EVO IX/STI Brembo MKIV Supra TT (need adapter plate front and rear)FD RX-7 (need adapter plate front and rear)90-96 Q45 Brakes (NO-Repet-NO After market support)
Sky Is The Limit...with time And $$$ You Can Fit F1 Brakes If you want..
Abd here Is A Pic Of My Front EVO IX brembo And Stock "ghay" brakes Rear :
Hope This help,
Ali
P.s
SEARCH Here And On Zilvia.net And You Will Find A Ton Of Info...
mxkid54
Car: 1996 240SX SE
If I am not mistaken the R33 GTST skyline front brakes are a little bigger in diameter than the 300ZX brakes. I have 300ZX on my S14 and I 've got a set of calipers and rotors from my R33 front clip. If interested they are for sale, email me.
MastaYu
Car: 92 Nissan 240SX SE HB
