franknitty69 wrote:the reason that i'm asking is because i have an opportunity to buy R33 GTS-T calipers and rotors for $200 (front and rear). that's cheaper than i've found for the z32 brakes.
so the 296mm x 32mm calipers and rotors will fit?
The 280x28s will clear the 15s with only a 10mm spacer. you have to have 16s I believe to clear the 296s, maybe 17s.... i dont recall, i know its TIGHT with the 15s and the 280s.
thats a pretty good buy for calipers and rotors... Id do it. I would DEFINTIELY buy them even if you just resell it.
