brake upgrade s13 nissan 240sx from a z32 300z
ralp2
Car: 1993 nissan 240sx se
if somebody can give me advise i want to up grade my brakes from my s13 240sx to a 300z z32 and i was told that the spindles are direct bolt on and also to get the master cylinder but if i get a tein suspesion is there going to be a problem?
http://www.240sxTech.com
Suspension won't matter - It's a fairly simple swap.
ralp2
AZhitman wrote:http://www.240sxTech.com
but my questions is that if i buy suspension does has to be one for the s13 or it has to be for the 300z ? cause i am putting a tein super drift suspension. thanks for the advise.
gumby74
The Z32 article seems to be a dead link.
ShootToKill
Car: S13
use search tool, and google is your friend. i think there are like 400+ write up on this.
ralp2
i have been looking arround but sims like all the swaps have been done from a s14 chasis and i have a s13 wich is my big problem and the thing is i dont want to spend al this money for nothing but thanks guys i really apreciate the advice. i will keep searching .
Agani, read the brake swap article.
No need for Z spindles because there's not a huge need fr Z32 rears. S13 brakes are VERY front-biased.
You won't use Z32 suspension on your S13 because of a brake upgrade, even if you DO swap the rear uprights. Front uprights will remain the same.
ralp2
the article in 240sxtech.com is down is not there.i found this guy that did that did the rear brake upgrade and he kept his four lug hub i want to upgrade to 5 lug i gues i wil have to get the hub from the z32 spindle and for waht he show in the picture the spindles are different where you mount the strut.now for the front i dont know is there is any difference between the z32 spindle and the s13 spindle?
working4aS13
Car: Base 95 240SX
Hijacker
Car: '92 240sx Convertible
'94 F-150
AZhitman wrote:You won't use Z32 suspension on your S13 because of a brake upgrade, even if you DO swap the rear uprights.
Do tell. Unless you're using a Z rear damper or went with coilovers that you can change the lower mount, there's no way you can use a rear Z upright.
On a side note, I've had a HICAS car up in the air, and I do believe that it uses the aluminum Z32 rear upright as it had the same fork style damper mount.
ralp2
my 240 has the super hicas thats another thing i have to deal with what about just changing the hub from four to five lugs and at the same time upgrading the z32 brakes?? cause i think that is possible. do you think that the z32 hub is going to fit in the 240 spindle if i press it in ?
