brake upgrade options
xsparc
ok as we all know the stock brakes suck. i want better/bigger brakes but i i have really expencive 4 lug rims. what options do i have that will keep my lug patter? thanks for your help
WongFeiHung
Altima rotors w/ Maxima calipers...Virtually the same as the 180sx front brake setup...
You can also do a Q45 brake conversion if you redrill the rotors...
xsparc
ok thanks, but what year altama and maxima?
solaris22
WongFeiHung wrote:You can also do a Q45 brake conversion if you redrill the rotors...
and redrill z32 rotors, believe they're the same as the Q45, type-m r32 are the same as z32 brakes too, I'm in the process of doing this. I say don't waste your money on 180 brakes, they're not worth it
