Brake Upgrade options
DJ Last Asian
Car: 90 S13 Hatch Base w/all Power 5spd
Car:S13 Hatch95 J30 VLSDKA24E
Story:My garage is filling up with brake parts. I have a set of S13 ABS calipers and J30 with rotors. I tried to swap to the abs but my brake line was not long enough to connect to the caliper. So for now I'm just using stock everything. I could get some Q45 brake system soon for cheap and upgrade. I still have the same problem as I did with the J30 with this upgrade. I would have to drill for four(4) lug. Finding rotors for the 300z that are alreadydrilled for four(4) lug are easy to find already done. (I don't trust myself drilling somthing[trying to stay away from killing myself]) Thank you in advance.
Question:Would I be able to use the 300z rotor on the J30 or Q45 calipers?
Space Monkey
Car: 1990 Nissan 240sx
I think the 300 rotors come in 30mm and 28mm, while the J30 and Q45 are 26mm. If this is the case then no you cant. I could be wrong though.
