Where can I get the special bracket? If I upgrade to the big brakes and 18" wheels, can I use the 15" piepans that I'm currently riding on for 3 months during winter, by using spacers or something or will I have to buy new winter wheels too?hardmoney wrote:Yes they'll fit, However you have to buy a special bracket to run the 12.8 inch rotors and have at least 16 inch wheels for them to clear. if you run a search you'll likely find a wealth of info on the subject.
Check on line, but if you know a good fabrication shop they should be able to make something, but it won't be cheap ($$), unless it's cheap .lino wrote:Where can I get the special bracket? If I upgrade to the big brakes and 18" wheels, can I use the 15" piepans that I'm currently riding on for 3 months during winter, by using spacers or something or will I have to buy new winter wheels too?
I'm only interested in something from an oem application, nothing aftermarket and sick expensive. First, I have to decide which brake setup I'm interested in and then once I know that, search for the parts. I believe I can buy used oem parts for reasonable money from wrecking yards and ebay. I'm in no rush. I just don't want to be due for a brake job and not know what I want and be rushed into buying something on the spot.maxnix wrote:Bigger Brembos an APRacing will fit. How big is your wallet?
Look at the Brembos on a R34GTR.lino wrote:I'm only interested in something from an oem application, nothing aftermarket and sick expensive.
Yes they are GTS and apparently Nissan doesn't carry the rear caliper rebuild kit for the R32 or Z32 anymore. Probably will be OK w/o but I was trying to eliminate any potential causes of a brake modulation problem I was having.elwesso wrote:Are they the GTS-T or GTR brakes??? Either way, they use the same pads, but the GTR calipers just have different dimensions. What im getting at, is you should be able ot use a Z32 rebuild kit.
However, on the 2 Z32 conversions ive done on a Q, ive never rebuilt them, and im almost at 1 year on my Z32 brakes.
Robert, 44120-43P26 is no longer available according to Scottsdale, I'll try NAPA. Do I need to get the other parts as well?RobertsnewQ wrote:44120-43P26 is the rear seal kit (rebuild kit)44080-43P25 is the rear hardware kit (pad shim/retractor spring kit)41217-43P00 are the pad pins for the rear41090-43P00 is the anti-rattle spring "H-spring" for the rear
All of these parts are still available through any Nissan dealer (as of last week).
Fronts only, I presume.one ton garage wrote:Full brembo upgrade from an oem nissan application will run you 1500 if you're extra lucky, to an average of closer to 1800-2000. Depending on the brembos you get, replacement parts for them can actually be easier to source than for the nissan 4pot front/2pot rear brakes, as a lot of other cars that use brembo brakes as oem used similar components... for example, you can get the bmw 850 brake pads for r32 vspec2 brembo calipers, etc...
No - I was speaking specifically of using the Brembo calipers AND rotors. The Yugo Bernie kit is nice, but does not use the Brembo calipers.
Even with the brake deflectors you still gotta be on the pedal PRETTY hard to fade the Z32 rotors.nismofly wrote:just to add something to what wes was saying
bigger brakes do not shorten stopping distances, in many cases theyll make it longer
pads with more bite and better tires will shorten stopping distances
larger rotors will resist fade better, but only if the pads you have are not the reason you have fade in the first place
because of this, z32's and comparable are fine for pretty much any street driven car, anything more is just for looks
