What is happening to the rotors that you need to have them machined every ~3500 miles?g37rocket wrote:i've already had to machine my rotors once at about 3500 miles and now i have about 6800 miles on it and i have to machine it again. the dealership say they can't replace the rotors under warranty until it gets down to a certain measurement so i'm just looking at replacement options
Its prety hard to warp a rotor these days. Espically one as massive as the G37S brakes. I'd look for a recurring thickness varioation that may have been started by uneven pad deposition. Especially since the vibration came back. This might be a sign that the uneven pad deposition has become cementite and is wearing unevenly. Turning the rotors will only temporarily solve the problem as it will remain smooth only until the hard spot in the rotor begins to become a high spot again.Kendahl wrote:Steering wheel shake points to warped front rotors. The service department needs to look for what's warping them, not just machine them again and again.
Actually, the softer OEM pads have a higher coefficient of friction upon initial cold application typical of street driving.Sentientbydesign wrote:Somebody made mention of the fact that most drivers have slow reaction times, so in order to make up for that, auto manufacturers use soft brake materials to assist in emergency braking.
Quality aftermarket brakes will outperform in all other areas.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
