http://www.conceptzperformance.com/Cart ... 91.126.178
can get everything brand new for $1650, or $1900 for stoptech rotors, stainless lines, and motul fluid. personally i recommend brembo at best or wilwood, the only thing you gain from the bigger diameter rotors is better heat dissipation which i doubt very many people need much better then the oem brembo. in essence you are greatly reducing performance for no benefit, you gain heat dissipation but if you dont need it then that pro is null, which leaves the negatives of increased stopping distance, poorer suspension performance, and slower acceleration from the additional unsprung and rotating weight.
i can tell you i have made multiple(5+) high speed slow downs(135+ mph) and have had 0 issues with brake fade on oem 03 enthusiast brakes, not even brembo. a 6th run might have been too much and only reason ill be going to brembo or wilwood 13 inch since its unlikely ill even need that its more of a safety issue against fade.
now you ask but it had bigger rotors, bigger pads, and bigger calipers it must work better!? this would be false, those systems(minus mayby the akebono which is designed for a slightly heavier car but 27 lb rotors is absurd imo thats 40% more then my 18x10.5 wheels weigh.) are all designed to have the same piston volume, sure more pistons but they are all smaller, this means that your pressure at the caliper pre pad is identical to oem or within a margin of error as to not effect brake performance, this means you have a larger pad biting on the rotor with the same pressure resulting in lower clamping force. to demonstrate this imagine pushing on a 1 square inch brake pad with 1 pound of force, the clamping force is 1 psi, now imagine keeping the 1 pound of force but increasing the brake pad to 2 inchs, you now have .5 psi clamping force. the additional friction surface will help negate this some but at the very best your going to have less performance then just putting a racing pad in a oem system, similar to how a 6 puck will always outperform a full face with the same materials and pressure plate. now the larger pad WILL last longer but its not helping your performance at all, if you want better performance get sticky tires i guarantee you will hit the limit of your tires before you hit the limit of your brakes. if you find the limit you need to do a custom setup off a heavier car that has a larger piston volume then the 350z, like the gtr or m5.
