Brake Suggestions
sr kid 88
Car: 91' sr240
ook so i have a s13 and i have stock brakes im looking into an upgrade so i can stop my 400rwhp easier and not have to worry if i will make the turn around at the end of the track im trying to keep 4lug but i will consider any input here is what i came up with for a possibility soo far
Circuit Sports Drilled/Slotted Rotorshttp://www.pdm-racing.com/prod....html
http://www.frsport.com/Brake-Packages_c_19.html
http://fastbrakes.com/shop/index.php?cPath=30_41one of these for fronthttp://fastbrakes.com/shop/ind...1_214 for the rear
let me know what you think would be the best upgrade or any other opinions. thanks
adrianfromthecastle
Car: 1992 Nissan 240sx
the ones youve suggested are still retaining the oe brakes (cept the last few links)
honestly, I think you need more stopping power since you said you have more than 400hp.
http://www.arizonazcar.com/240sxbrakes.html
that or some z32 front and rear calipers, pads, brembo rotors, ss lines, MC, etc. You can still retain the 4 lug if you get the rotors redrilled to 4 lug. The rear shoe will need to be replaced with z32 ones for the ebrake though.
blackbetty
well you could go with z32 brakes.
or just do pads, lines, and rotors on the stockers.
But what are you running at the track? mph?
http://www.splparts.com
AZ89two4Tsx
You're running stock brakes on a 400HP 240?!?
heartofaskyline
Car: 1992 hatch, 1993 sr20 coupe
q45 ive heard arent bad, and its easy to find wheels that clear them.
blackbetty
AZ89two4Tsx wrote:You're running stock brakes on a 400HP 240?!?
honestly thats not that bad? I mean for all out autocross, road coarse, time attack etc yea it would suck because of brake fade on the weak, thin rotor'd stocker units.
But for daily driving its not bad.....70 mph is 70 mph no matter if you have 1000hp or 250hp.
But if he's only going 115-120 mph in the 1/4, stockers should be plenty.....not like he has to stop on a dime or anything.......
depending on what he has planed for his car......an upgraded pad, line and rotor could be fine. But if you have any hard spirited driving or road course type plans, just go with the z32 upgrade (or the q45 etc).
nissanman04
Car: '90 240SX, '95 Subaru Legacy
If you are just drag racing, I don't see why some new blank rotors, new pads and fresh, high-temp brake fluid wouldn't work. It's not like you are doing repeated high-speed stops without a break in between.
adrianfromthecastle
so are we all to assume this dude's 400hp car's purpose is just drag or daily?
LOL
blackbetty
well he did say "and not have to worry if i will make the turn around at the end of the track" so........
to me thats all he is worried about......
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
That kit price was high for a aftermarket Z32 set up. Just go with Z32 brakes around the car. I make 500 horses and I think they are going to be just fine.
I paid about 750-800 for my brakes all around (Rebuilt front Z32 30mm's, Z33 track rotors, bracket, pads, New rear calipers, brembo rotors, backing plates, cables, and all new hardware)
sr kid 88
Car: 91' sr240
my car is daily driven and track car, just wanted to upgrade brakes since that and some other suspension is left on my to-do list/ probably willing to spend about 800-900 on the whole setup
sr kid 88
Car: 91' sr240
which requires less modification. if i upgrade calipers wouldn't i have to do something with the e-brake?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
There is a l lot of info if you search. But to use Z32 rears you will need the rotors, calipers and pads of coarse but you also need the shoe type backing plates and e brake cables. If its a S13 2+2 cables, if its an S14 use R33 cables.
I used standard Z32 cables on my S13 but it was a task to do.
