ricebike »
https://forums.nicoclub.com/ricebike-u5064.html
Sun Jan 14, 2007 1:09 pm
or do this...
un mount the rear calipers, turn the pistons into the bore by 90 degrees only to allow some space between the caliper-pads, (90 only to keep the piston tabs aliagned to the pads' alignment nipples <shrugs>
remount the calipers as well as the freshly lubed sliding pins & don't forget the parking brake cables...
go drive to a parking lot & hit reverse while applying brakes to get the pads readjusted to the rotors again...
