gordonliu »
https://forums.nicoclub.com/gordonliu-u37714.html
Wed Jan 24, 2007 9:35 am
i have a 92 240sx coupe with z32 aluminum calipers all around, with some cheap ebay drilled/slotted rotors (5 lugs), 17/16 tokiko z32 mc (no abs), and stainless lines all around (with rear hybrids), with hawk hps pads.
the brakes are excellent, except that everytime they get hot like after repeated hard stops, i begin to hear a squealing/grinding (not like hardcore metal on metal, just a more accurate description of the noise) noise comming from what seems to be only one of the wheels. there is no problem braking whatsoever.
one of my mechanic friends told me that because all of my components except for the used calipers are new, that it is most likely because my calipers are not applying enough force on the rotor and so are allowing it to slip at higher temperatures. im trying to figure out if i need to source a new caliper, or if i have some other problem.
thanks
