brake rotors same between m35 and m35x?
bfournier
looking to replace the OEM rotors with non-rusting (coated) rotors. Are all four of the rotors the same on an m35 and m35x?
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Per FSM, the M35/M45 rotors are the same - Front=28mm new/26mm min; Rear =16 mm new/14 mm min. Make sure the replacement rotors will give you the same or better stopping power than OEM.
Poyzinous
Car: 2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
Part Number 40206-EG000 is used for ALL Y50 models. Rear rotors are 43206-EG000. also goes on all Ms.
ken in az
Car: 2011 Infiniti M56
2002 Chevy Silverado
1989 Nissan 300ZX
2008 Ford F250 Diesel/Canam X3 Turbo
So does that mean the G37 BBK would fit the X models as well?
Poyzinous
yes, if it isnt a sport model.
ken in az
1989 Nissan 300ZX
Poyzinous wrote:yes, if it isnt a sport model.
If what isn't a sport model?
The BBK is the stock setup with 14" rotors from a sport model G37. They are a direct bolt-on for the M35 and M45 06' and up. If the M35x and M45x share the same brake components as the non X model then the G37 sport BBK should fit them as well.
Poyzinous
If the G isn't a sport model with akebonos.
ken in az
1989 Nissan 300ZX
Poyzinous wrote:If the G isn't a sport model with akebonos.
Thats exactly the BBK I was talking about. Why wouldn't they fit an X model if they fit a non X model?
Poyzinous
hub and spindle/knuckle are different. And the wheel offset/clearance.
ken in az
1989 Nissan 300ZX
Poyzinous wrote:hub and spindle/knuckle are different. And the wheel offset/clearance.
Right - the M35/45 non sport wheel only needs a spacer just like the M35/45 sport wheels do.
But the Rotors are the same and so are the Calipers - so the BBK should fit the X model exactly the same as it fits the Non - X model.
I'm not seeing your reasoning for them not fitting, can you elaborate anymore on why?
thanks, I'm just trying to open up the G37 sport BBK to the X guys as well.
Poyzinous
Wow. you're fun to talk to. Just like with the oil thread... Well the M35, M45, V36 model G35 and G37 all use the exact same spindle, so the calipers should be swappable between all models, as well as rotors. Most of the hubs are the same, between RWD and AWD models. The fitment issues would be due to wheel and hub combinations between 18" and 19" wheels and the AWD hubs and RWD hubs, but I doubt the hubs are any more than 2mm apart in offset.that answer your Q's?
ken in az
1989 Nissan 300ZX
Poyzinous wrote:Wow. you're fun to talk to. Just like with the oil thread...
Wonder what took you so long to realize
