Racingswh »
https://forums.nicoclub.com/racingswh-u19129.html
Fri Sep 03, 2004 5:25 pm
I use cross drilled and slotted rotors on my 1990 240SX. I use the car on the street as a daily driver and the car makes 2 to 3 trips a year to racing tracks in the east such as Watkins Glen, Summit Point, and Pocono, all road courses. The story is that under extreme use cross drilled rotors have been known to crack starting at the holes. (I have another track only car and it has factory cross drilled rotors and I have no problems) For extreme use (serious track duty) slotted rotors expel gases well enough and are more durable. If your car is stock or going to be driven on the street or at the track on street tires I think drilled and slotted rotors are fine. I have had no problems whatsoever with warpage. With a change of the rotors, pads, going to braided steel lines and using high quality fluid such as ATE Super Blue your cars braking will be dramatically improved! Good luck.
