Brake rotors and pads?
floodshark
I'm looking into just replacing my rotors along with my pads, but all the places I look at want to know if it's an ABS equipped 240 or a non-ABS equipped 240 for the rotors.
Uhh which is it for the convertible?
guyaverage
Car: Nissan 240SX Convertible
Front uses ABS pads and rotors. Rears use non-ABS.
At least mine does.
Hijacker
Car: '92 240sx Convertible
'94 F-150
all convertibles recieved the ABS pads and rotors. Even though it doesn't have the ABS control unit. The ABS pads and rotors were slightly larger than non ABS units, so non ABS equipment won't work right.
rears are the same between ABS and non ABS versions
floodshark
Great, thanks guys
TurboChargedSE-R
Car: 1993 Nissan SE-R with a BIG turbo
1993 Nissan 240SX convertible KA24DE-T
I just learned this one the hard way. I had a caliper pin that was stuck in the bore of the caliper bracket. Bought a pair of used caliper brackets off a 240 coupe.
Nope. Too small.
At MonkeyZone, etc. you want the brake pads that end with the numbers 485. The 422s they will give you if you ask for regular 240 brakes are way too small.
Chalk one up to live-and-learn.
zer013
Car: 1993 Nissan 240SX Convertible
im going 5 lug using the stock calipers. do the s14 5 lug rotors work?
STARBUCKS
Car: 1992 240sx Coupe SE
My car has non-abs brakes on it...
madcowvert
no your car has abs brakes but your car is not abs..
to help the car brake better for the extra whieght they used abs rotors and pads.
STARBUCKS
no my car doesn't have abs pads and rotors on it... because i just put ebc green stuff pads and brembo rotors on it that are for a non-abs 240sx...
i'm not ignorant.. i understood what the thread stated...
madcowvert
We’ll being that your new to the forums I thought that maybe you didn't read the whole thing and just answered the top post but hey don't get so defensive...
Now you can put non-abs rotors and pads they will fit they remember they are smaller. But what you were supposed to get is abs rotors and pads.
STARBUCKS
madcowvert wrote:We’ll being that your new to the forums I thought that maybe you didn't read the whole thing and just answered the top post but hey don't get so defensive...
funny you say that, because i read this thread before i put my brakes on but after i already bought them... so i measured the thickness and diameter of the rotor with a dial caliper and they measured the same size... well actually the new rotor was a little bit thicker, but i assume thats from the origonal rotor being old... so i measured the pads and they were exactly the same...
so like i said my car doesn't have abs rotors/calipers on it..
94_240sx
Car: 94_240SX
I'll add Nissan OEM part number to this thread.
Front Rotor: w/ABS R/L 40206-71E06
WHYTEBO1
Car: 93 240sx
hey i just bought ABS pads but non ABS rotors for the front for my 93 240 hatch. thats fine isnt it.
biggie
WHYTEBO1 wrote:hey i just bought ABS pads but non ABS rotors for the front for my 93 240 hatch. thats fine isnt it.
No, you need ABS type rotors.
