brake rotor weight?
DevZX
Car: 1990 300zx twin turbo
1995 miata mx-5
1990 miata mx-5
how much do the stock brake rotors weight? im trying to lose as much weight as i can. so far i deleted ac, aiv, egr, carbon canister, plenum hoses, spare tire jack. hoping to remove more soon.
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
So you're going to remove the OEM rotors? :)
Stock rotors weigh 17.5 lbs.
SZ 2-piece stock-sized rotors weigh 12.5 lbs, and that's unsprung weight savings.
Also, 2 piece 350Z track rotors weigh the same as OEM at 17.5 lbs, but you get greatly improved braking.
raremotive
Car: 04 Infiniti G35
BigTDogg (MA) wrote:So you're going to remove the OEM rotors? :)
Not to mention it's also rotational weight. Should bring you up to speed in no time, but will it stop you too? :chuckle:
