Brake rotor removal
RoyDaGeneral
Car: 2002 Infiniti QX4 2WD
This is my first time working on brakes. I'm stuck and can't remove that rotor. Do you pop that center cap, I don't want to force it out.
RoyDaGeneral
Anyone, truck is on jack stands!
RoyDaGeneral
I've popped that center cap and removed those two circular retainers, but it won't budge. Anything else to remove. Looks like bearing is right there. I did not find a C clamp in there like some of the online videos show. I tried hitting the rotor but no go!
AlanAZ
Car: 2003 Infiniti QX4 RWD
It's been too long since I did it myself, but it's all in the Factory Service Manual, above in the pinned 'Information and FAQ' thread, and the brake rotor and pad replacement and the front bearing threads within the pinned 'How to' thread.
RoyDaGeneral
Thanks Alan, I ended up watching a video for an Xterra, and the next step was just to pull the rotors straight out which forced the bearing to come out first. From there it was not a problem.
macgiver
Absolutely , that's not just a rotor - that's a complete HUB assembly , integral w/rotor ,a little more to them :chuckle:
attofarad
Car: 2001 QX4
Careful when you put the retaining ring screws back in --they are very soft metal and will strip their screwdriver slots easily.
Also, be aware of the procedure for setting the bearing preload with that threaded ring in your second photo. Have you downloaded the maintenance manual pdf yet?
RoyDaGeneral
attofarad wrote:
Sun Jun 30, 2019 10:55 pm
Yes those screws are made of a soft metal, I might have stripped head of one of them, I'll have to buy some new ones for next brake job. I was not aware of a service manual for our cars on this forum. I am a newbie here and still learning about how to navigate this web of new info. I just downloaded it. Thanks for pointing that out, Attofarad!
