maxnix »
https://forums.nicoclub.com/maxnix-u127.html
Wed Jul 30, 2008 5:57 pm
Always replace rotors and pads in pairs. Good to have a shiim kit on hand if you need it. Replace brake fluid also with DOT4.
The Brembo rotors are very good, but corrode like a cheap tin can. If Joe is running a special on the Stillen Brembos, I prefer them as they are plated. OEM pads are the best for everyday street driving.
Don't neglect the rear brakes as they may be untrue also and the pads wear fast due to the rear brake bias. Be sure to adjust the emergency brake while you are performing this maintenance.
Turning the rotors is the least expensive on the short run, but you will be back sooner as there is less thermal mass when you are finished.
That's the sum of my experience with all 3 types: OEM, Brembo OEM Replacement, and Stillen Brembo OEM replacement rotors. Long run, I much prefer the Stillen Brembos.
