Brake Rotor Fitment Question
naVan
Car: 1996 S14 Silvia Zenki K's Aero edition
hi members,
recently i decided to change my brakes plus pads on my S14.i have been looking for parts over the internet for 2 days by now and i have a question.
chassis code : E-CS14 . Model : GBYBRUFS14UD4TEMBL
1.OEM Rotor size of front brake is 280mm ? IF YES !
2.if yes,will a z32 rotor fit with stock caliper ? (stock caliper is 4 piston)
3.using stock caliper,are there any more replacement options available ? (like r32,r33,z33 etc)
cheers all.
naVan
http://www.frsport.com/Brembo-OE-Replac ... 15411.html
z32 oem replacement rotors.
but i am not sure if my calipers are 30mm :(
naVan
ANYONE ! :confused:
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Stock should be 258x22. You can use the z32 rotors if you use the z32 calipers as well.
naVan
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
I just realized that you are not in the US. Z32 rotors will work just fine. Sorry about that.
