SilviaS14KA24DE »
https://forums.nicoclub.com/silvias14ka24de-u14571.html
Fri Oct 07, 2005 2:25 pm
ok i got my breaks done 2 months ago and they're squealing like a pig in a toaster.
It's weird, the front breaks don't sqeal at all, but only the rear ones do. Especially when I reverse, it sounds horrible. I have Duralasts on all four corners.
I was thinking maybe since my car is dropped 1.75'' all around, the rear camber will crap up my breaks? Maybe get a RUCA to correct the camber (does camber have anything to do with squealing breaks?) Correct me if I'm wrong. Another thought was that my break pads are just crappy and maybe I need a better brand of break pads- but remeber my fronts have them also and don't squeal.
The last thought is that the piston set up is crap. The rears are like any 240's (those damn pistons you have to twist and align). I know if they're not aligned, they're put on wrong, although they're aligned to the pad perfectly. Should i get different calipers? Like the type of calipers on the front breaks? If I should, off of what car or brand? Will J30 breaks work? I really dont wanna deal with twsiting the piston inwards just to fit on the pads. I'd rather just push them in cause it's much easier to adn i dont' have to alight it perfectly.
Oh and yes I've thought about 300zx break upgrade if this is the way to fix my breaks.
Please help! I'm gonna get the rotors resurfaced (again) and try it out again but I would like the rid the problem once and for all (I really, REALLY hate annoying sqeaky breaks).
