dcg129 wrote:I don't know about your car, but I believe all brake systems have a 4way valvue that makes sure the master cylinder delivers the same pressure at all 4 brakes. I forget what they call it to but that might be a possibality
It's called a proportioning valve.
kenversusryu wrote:It really does feel like the left side of my car is lunging more than the right side resulting in a pull. As if the brakes are failing on the left side. Checked everything out though but still no answer. Maybe I missed something.
Can incorrect toe result in a pull? My steering wheel is off and it points to the left. When i drive 15 mph and brake the steering wheel points straight. Anything faster than that and brake will pull to the right.
Hope that helps a bit.
Incorrect toe can cause a pull but, it won't straighten itself out as you go faster. Did you replace both front caliper? If you replaced just the left, then you replaced the wrong one. If you're pulling to the right, that means the caliper on the right is dragging.
