brake problems???? please help!!
Redzunz
Car: '90 300ZX TT
my z32 brake fail yesterday, its making grinding noise on the brake pedal and is very hard when pressed, please help.
marty1mc
Car: 1990 Nissan 300ZX TT - Z owner since 2003
First, How mechanically inclined are you? It sounds to me like you have worn through your pads and have metal to metal contact with the rotors. Usually means you are buying new rotors AND pads...
canadian booster
Car: 1993 Nissan Z32 TT JDM
first thing to do, anyone can do this i think..
- check brake fluid level and make sure it's ok
- take off a front wheel and look at the brake assembly. you should see the outside brakepad has a bent sort of piece of metal (called a squeeler pin), is it touching the rotor? if so you probably need new pads and rotors pretty bad. i circled it here (this is the side facing the rotor on your car):
what do you mean when you say the brakes failed? did they not work at all, or do they lock up and screech the car to a halt very quickly?
you said the pedal is very hard to press, so it sounds like a problem maybe with the brake booster or a vacuum line
aviatorwes
Car: 1992 Nissan 300zx TT (NA-TT Swap) & 2002 Nissan Altima 3.5 SE
Did you press the pedal and the car didnt want to stop and the pedal was hard as a rock? while you're checking the brake fluid check the vacuum line that runs from the booster to the check valve and then to the intake manifold. That still doesnt explain the grinding tho. Like stated above what exactly do you mean by failed?
Redzunz
Car: '90 300ZX TT
when i mean failed is the car just dont stop had to use E brake to make it stop, now when i pressed the brake pedal it had a little pressure and if press it deeper it start making grinding noise on the brake pedal. could it be the master cylinder???
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
aviatorwes wrote:check the vacuum line that runs from the booster to the check valve and then to the intake manifold.
No joke. I blew that line off during boost one time because the hose clamp wasn't secure, and I had a really hard time stopping. I was literally pulling on the steering wheel while standing on the pedal with both feet trying to stop.
If that line is secure, I'd look to the master cylinder or the brake booster itself.
es.biggs
Car: 1990 300ZX 5sp NA
Grinding noise sounds like metal to metal...check your pads like said above to make sure you have some meat on them still.
