Brake Problems!!!!! NEED HELP PLEASE
drifterhype
Car: Nissan RPS13
I have a 89 body with a SR20DET swap and when i first took my car for a drive, everytime i push on the brake peddle it kept getting harder and harder and so my brakes wont releasing. when i open the bleeder by my tires the caliper realeses, i can't figure this out. is it my master cylinder or brake booster?
carkook
Explain more, so as your driving your brake pedal gets more and more difficult to push down, and then your brakes lock up? Is it all four calipers? If so the compensating port in your master cylinder is clogged. I would just replace it there pretty cheap.
drifterhype
Car: Nissan RPS13
Ya it's like that but i'm not sue if all four are locking up becouse when i open the bleeder for one of the front ones only because they are the easer ones to get to the brakes release. My brakes don't just lock up it's every time i push the pedle witch is really hard till i open the bleeder they keep compresing and little release till they are on there. This has stumped me and is pissing me off cause i don't have as much time as i wish i can to check it out that's why i came to ya.
drifterhype
Car: Nissan RPS13
And also i got a top mount T3 T4 with out a heat sheild or turbo blanket, can that mess up the master cylinder to because of the heat?
carkook
Well Get the brakes to lock up or watever, then jack the car up and see if they are all locked up. If so replace the master cylinder. And yes It can melt the resevoir=BAM no fluid/pressure
drifterhype
Car: Nissan RPS13
Thank i'll do that this weekend and keep you updated, thanks for the info.
