pcbootleger »
https://forums.nicoclub.com/pcbootleger-u8418.html
Sun Jul 06, 2003 7:46 am
You might have a leake somewhere. See if you can spot a leak yourself. Otherwise replace your brake lines, calipers and possibly the master cylinder and whatever else is part of the brake system. But try to verify where the leak is first.
If you have a z31 you may not have put your caliper on correctly. There is a thing that looks like a cut washer (flat on two sides then round on the other) It has to be placed correctly when put back on. I had that problem on mine and it did make a significant amount of difference when rearranging that small peice.
