Brake problem
Jornez
Car: 1995 240sx
So the other day my brakes decided to stick, and felt like all of my brakes stayed engaged, and my pedal got stiff as a board, but after sitting for a while it releases and feels normal, but repeats the problem once driving and using the brakes. I changed my brake master cylinder and the problem still exists, would this be the proportioning valve? If not, any insight?
masterdisaster
Car: 1991 JDM 180SX
check for deteriorated rubber brake lines
jack the car and check which brake is sticking .. could also be a sticking caliper..
you could also bring it to a garage if you don't fell confortable working on a critical system.
up here, all brake inspections/estimates are free
Jornez
Car: 1995 240sx
masterdisaster wrote:check for deteriorated rubber brake lines
Would a faulty caliper cause all calipers to stay engaged?
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
No, you have another problem.
Jornez
Car: 1995 240sx
Would a bad rubber line or bad proportion valve cause this?
sx moneypit
1986 Toyota MR2
It is not going to cause all of them to stick.You need to check and see if in fact if all of them are sticking and go from there.
Jornez
Car: 1995 240sx
Well, all of the wheel wells had smoke coming from them , So im only assuming that they are all staying engaged
sx moneypit
1986 Toyota MR2
Remove your master cylinder and adjust the push rod in and see if that takes care of it.
Jornez
Car: 1995 240sx
Would that be a problem if i never messed with any of that?
sx moneypit
1986 Toyota MR2
You could have a brake booster problem.
Jornez
Car: 1995 240sx
sx moneypit wrote:You could have a brake booster problem.
hrm, just got off the phone with Nissan, and 240sxs do not have proportion valves
Cone Junky
Car: S13 fastback
BMW e46 328i
sx moneypit wrote:Remove your master cylinder and adjust the push rod in and see if that takes care of it.
Good place to start
Jornez
Car: 1995 240sx
Would the push rod be a problem if ive never tampered with it and it just out of the blue started acting up?
dpr2w
Car: '92 240SX
'14 DBA-R35 GT-R
Try checking the pressure line going from the engine valve cover to the brake booster. There could be a hole or bad connection there. The pedal will get stiff whenever the booster is not getting pressure from the engine. Whenever a car is off and you depress the brake the pedal ends up getting stiff due to a lack of pressure in the brake booster. I would check there first and then look for leaks. You may also want to lubricate the pads, shims, slides, etc. to ensure nothing is catching in the calipers themselves.
sx moneypit
1986 Toyota MR2
Jornez wrote:hrm, just got off the phone with Nissan, and 240sxs do not have proportion valves
What does that have to do with a booster problem?
Jornez
Car: 1995 240sx
Lol, nothing at all, I didnt mean to reply with that, but would the booster even do something like my problem?
Jornez
Car: 1995 240sx
Is it normal to pump the brakes at idle and the car drop about 300rpm? Ive never recalled it doing this
masterdisaster
Car: 1991 JDM 180SX
Jornez wrote:Is it normal to pump the brakes at idle and the car drop about 300rpm? Ive never recalled it doing this
isn't it suppose to drop @ first .. and then go up ?that's if you constantly pump it
can someone confirm ..
locoluna825
Car: 90 240sx coupe
if its a good master cylinder, I believe its not supposed to drop. especially down to 300 thats way to low.
Jornez
Car: 1995 240sx
Well I got down to it tonight, I took off my brake boost (no rust holes), all calipers, (back left seemed to be half way stuck engaged), i have 2 warped rotors, not torn lines, and fairly clean brake fluid, Im going to go get my 180sx rotors resurfaced, new (to me) calipers cleaned, and new pads, im hoping there was some problem in the way that replacing this stuff will fix
Modified by Jornez at 8:39 PM 3/25/2010
