it only vibrates when i press on the brakes. havent changed brakes. still stock. does this mean i need new brake pads?downedzephyr wrote:does this vibration occur during normal driving? and have you changed your break pads in a while?
Unless you're really driving hard and constantly mashing your brake, you shouldn't need new pads. I would guess that your brake pad and rotor disc are misaligned. Generally, this is a result of warped rotors, so I would take it to either your dealership or shop to get this checked out. If it is a warped rotor, just have them machine it.eddyZ wrote:
by warped rotor, u mean aftermarket ones? (i'm a car noob) then no, mine are all stock. but yah, i will take it in for a check up. thx.downedzephyr wrote:
Could also be from loose or worn out wheel bearings.
No, it doesn't have to be an aftermarket rotor. Your stock rotors can still warp. Also check out the asking a good question thread, this one was kinda ambiguous. Good luck with getting this problem solved!eddyZ wrote:
Probably a good ideacoupecrazy1232 wrote:um im at a year and a half and 33000 miles...so i am thinking i should replace them asap lol
