yellow_jacket »
https://forums.nicoclub.com/yellow-jacket-u4236.html
Sat Mar 01, 2003 7:07 am
More than likely this is a problem with one of the rubber hoses that run to the rear brakes. The easiest way to check this is to try and bleed the lines before any of the rubber hoses. If I remember correctly there is a single line running from the master to the back brakes. It then splits somewhere around the rear differential. Usually there is a rubber line that bolts up somewhere around there. May also be the proportioning valve, just start bleeding lines til you figure out where you are losing pressure.
