brake problem (right rear)
beans33
Car: 1993 ca18det 240sx
ok I got the car and at first i thought the caliper was locked up ...After I pump the brakes the car wouldnt roll, like if the e-brake was on. Bleed the right rear and I didnt tighten the valve back and it rolls just fine... if i tighten the valve back and push the brakes it locks up again. Ive tried another caliper and it does the same thing.. The car isnt running right now but i need to get this fixed
JeromeS13
Car: 2008 Subaru Impreza STI
Sounds like it could be a partially pinched brake line or the master cylinder.
-Jerome
RICERMAN
I would inspect both rear brakes for anything thats not kosher..Be sure ALL brake pads are sliding properly. that the caliper is secure and the lines are free and not pinched or binding. The poportioning valve may be the problem and not the master cylinder if you have a strong pedal that doesnt bleed down with foot pressure. If the car was repaired before you got it dont rule out any possible error that could have been made upon reassembly..........OH yea get a service manual for about 15 bucks and use it........you never ever want to guess about safe brakes
LayNLow240
Car: 92 240 coupe
or just go and download the FSM for your year for free.
but your problem sounds like a pinched line, clogged m/c or bad porp valve.
RICERMAN
Where is the web site for the free manual download? I didnt know of it. thanks
