Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Wed Jul 11, 2007 10:07 am
It's possible that the heat from the manifold could cause the fluid in the MC to boil, but that typically means that the fluid looses it's hydrolic nature and can start to compress resulting in a sloppy pedal.
Old DOT3 fluid can cause a sloppy pedal as well. DOT3 can absorb water from the air and begin to lose it's hydrolic abilities. That's why you have to leave the bottle sealed up unless you're pouring.
I have been running without a heat shield on my SR mani for 3 years now with no braking issues.
From the sounds of it, I would double check your calipers to make sure one isn't seized up. Then I would consider pulling the MC and booster for replacement.
The booster is pretty easy to get out:1- take off brake MC2-remove 4 nuts from inside passenger cabin holding booster to the firewall and brake pedal3-pull it out
