Brake problem!!! need help please!!!
DrftS13
Car: '91 Nissan 240SX (silvia coupe)
Hi guys I really need your guys help. I am running 300zx brakes front and rear on my S13 coupe. with a Z31 master cylinder and a z32 Brake booster but for some reason the brakes wont hold pressure...like i bleed them and then the next time you step on the brakes they go to the floor!....it really sucks!
the crazy thing about it is that i had the same brake setup with a stock S13 booster and it worked just fine....
please help me ive checked all the lines and nothing leaks
DrftS13
Bump: help please.
kevinarich
Car: S14
sounds to me like the master cylinder has either air in it. Or bad seals. you need to bench bleed that master cylinder.
