brake problem, help!!!!!!!!!!!!!!!!!!!!!!!!
s13drft89
Car: 1991 Twin Turbo 300zx & 1968 Mercury Cougar
Well, lets see how i can start this off, i had bought some new rotors for all around, well i had changed them all, and when i had put back on all the calipers i had blead each one, well when ever iam bleeding the pedal gets hard, but when i turn on my car, the pedal is all spungy, and about to drop to the floor, before i had change the rotors, the car would atleast stop without a hesitatin. I had blead the brakes atleast 4 times, going in the correct pattern, which it should be done, but same thing. Anyone know whats wrong, please any help would be nice thanks the car is a 1990 240sx
Craving4Boost
Car: 91 240sx fastback
your not bleeding the brake lines by yourself are you...if you are...thats wrong
s13drft89
of course not, i have my bro helping me out, i also had done it while the car was on and off
crzycav86
Car: 93 Nissan 240SX KAT
Wrong forum(should be in susp/brake)...
but anyway, are you losing fluid when you brake(while the car is on)?
EDIT: and do you have ABS?
BryanGrigsby
Car: Red 240sx SE
Craving4Boost wrote:your not bleeding the brake lines by yourself are you...if you are...thats wrong
I have a '98 and bled the brakes myself, and it actually works for the first time, everytime. Its one of those kits you can buy from napa, or autozone. It has a little resevoire w/ a magnet on the back. You fill it half up w/ fluid and open the bleeder valve, pump the pedal about 12 times, check for bubles and close her up. The trick is that you posistion the resevoire using the magnet on the frame or wheel well HIGHER up than the bleeder valve. Always works for me.
EDIT: did you put on new pads? The brakes can be spungy for the first bit after new pads.
