Ok, so I finally got the check engine light to go off. Followed the FSM steps and found out it was a broken wire of all things from the distributor. No more $hitty gas mileage :icon18
Then I moved on to brakes (just replacement). The fronts went fine, no problems. Went to the rears, get the pads out, and the damn piston will NOT go back in. I used a 6" C-clamp and the damn things won't budge. I detached the e-brake and that didn't help either. Anyone had a problem with a seized piston before? So I put the old pads back in (squeeling like mad) and said f*ck it for right now. :angryfire
