Brake Problem Again!
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
VIsa Versa
Car: 2008 Nissan Versa Sedan
Well after taking the V in at 6000 miles and the dealer changing the pads out, we have are still having an issue with the brakes. We took it back soon after, and they are still squealing to the point of embarassment! So DH took it in to a different dealer than the one we purchased from. And the tech said to DH "They haven't put a service notice out "YET" for the rear brakes". So they did some things to the rear brakes, and we now have no noise! NOT! On the way home they still did a slight squeal, but it is a marked improvement over what it did sound like. Ahh Nissan's famous brake issues. Oh by the way the V has 10,000 miles on it now.
vincent_18
What was the notice that they put out about the brakes??
VIsa Versa
ALL NISSAN MODELS; BRAKE NOISE/JUDDER/PEDAL FEEL DIAGNOSIS AND REPAIRThis bulletin is to assist you in responding to customer questions about brake operation,and provides diagnostic and repair information for each item listed, if any should occur.• Most brake incidents fall into the following categories:a. Brake Noise: A squeak, squeal, clunk, or groan that occurs when the brakes areapplied or released.b. Brake Judder: A vibration that can be felt in the vehicle, steering wheel or brakepedal when the brakes are applied.c. Pedal Feel: The effort needed to operate the brakes is too high or too low
Vahagn23
Car: Nissan Versa S
What causes symptom B and C?
VIsa Versa wrote:ALL NISSAN MODELS; BRAKE NOISE/JUDDER/PEDAL FEEL DIAGNOSIS AND REPAIRThis bulletin is to assist you in responding to customer questions about brake operation,and provides diagnostic and repair information for each item listed, if any should occur.• Most brake incidents fall into the following categories:a. Brake Noise: A squeak, squeal, clunk, or groan that occurs when the brakes areapplied or released.b. Brake Judder: A vibration that can be felt in the vehicle, steering wheel or brakepedal when the brakes are applied.c. Pedal Feel: The effort needed to operate the brakes is too high or too low
ziadc
Car: Nissan Tiida sedan 1.8 2008
Vahagn23 wrote:What causes symptom B and C?
http://www.lyberty.com/car/Max...3.pdf
lilredmnm
good luck! on my versa the squeeling of the brakes started at just 2k!! my car now has 8k and has been in 5 times!!!! (ive had squeeling, to grinding to vibration) after the 4th time i contacted nissan direct, they then worked with the nissan dealer here to correct the problem, k all went well for bout 1k miles, and AGAIN im having brake problems!!! so ive contacted nissan direct again and now there giving me run arounds, im so frustrated with nissan i could scream!! my car is now considered a lemon because it has had the same problem 4 or more times, so my step now is im looking into a lemon law lawyer!!!im happy for every versa owner that has not run into this problem!
ziadc
You should contact the Nissan service center manager/supervisor directly, these people do they maximum effort to not change and replace faulty parts they always tend to fix them instead.
Return to “Versa Technical Discussions”
