Don't know what MC means but here's what I learned in the past:
It's not recommended to do the 2 man pump bleed thing because if you don't initially prime the fluid drain tubing going into your waste container properly, you can easily get air pockets trapped inside the brake lines. The haynes manual is overall pretty good but it sometimes misses a few things( I have one and should know
). So the way I was trained if you're going to do it this way is to:
-get a large waste container2 liter soda bottle is great!
-Punch a hole with a screwdriver on the cap for your tubing.
-fill the container enough of brake fluid to where the tubing is submerged
-start with the bleeding process at the furthest wheel from the master cylinder (so passenger side rear)
- with one end of the tubing on the bleed nipple and the other submerged in the brake waste container have your helper pump the brakes until they are stiff
-with the helper still pressing down on the brake pedal crack open the bleed screw until you see a solid stream of fluid and no bubbling in the waste container (
This step is very important otherwise this may be an area where you can get air into the system.) Before the pedal bottoms out close the bleed screw and make sure the tubing is till submerged in the fluid. If done properly you should have no bubbles.
The problem people have is when your helper releases the pedal before you close the bleed screw and the tubing happens to NOT be submerged in the fluid you will draw in air as master cylinder attempts to return to it's idle state.
After this, follow the haynes manual and you should be good to go.
Another problem is when doing the 2 man method you are forcing dirty fluid through the piston seals inside the master cylinder which are like minute particles of dirty that can damage the seals. I've seen this and it happens quite a bit.
The better methods are vacuum bleeding and pressure bleeding. I have a Vacula bleeder similar to this one
http://usa.vacula.com/newsite/produkter ... oduct_id=6. You will need a compressor but it is so worth it!!!!
The pressure bleeding method is probably the best as it constantly supplies fluid during the bleed process but the equipment is a bit more expensive.
