solar07 »
https://forums.nicoclub.com/solar07-u238556.html
Thu Jul 10, 2014 7:59 pm
Hello all,
I have been over at the nissan club forever and finally made a jump to niCo.
I will try to keep this short but will need some detail. I have an 03 3.5 altima. Just just rolled 150k. I was having issues with sticking rear calipers after multiple attempts to replace the slide pins and such. I needed new rotors and pads anyway so I sprang for powerstops daily driver kit with rotors pads and rebuilt calipers. All are now new.
After the install I began to bleed the brakes. I was not getting a single drop of fluid from the rear right caliper and very little from the front left. The front right and rear left are pushing fluid out fine. I even pulled the brake line from the caliper and no fluid from their either.
I let the car sit for the night then came out and drove it up and down the drive way and got a little petal pressure back but not much. I jacked the car up for another bleed and now Im getting a little fluid out of the rear right and front left but still not as it should. Maybe a table spoon slowly.
The other odd thing, when I'm bleeding the front right or rear left which are bleeding fine the brake pedal pumps up nice and hard. When bleeding the rear right or front left, as soon as I Crack that bleeder then tighten, the pedal will not return to pumping up firm until I go to another wheel or let it sit.
I'm at a loss. Master cylinder? I pray it's not the abs pump.
