Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Wed Sep 14, 2005 8:21 am
would be a bad check valve or a leaky diaphragm in your booster. Start the car, without hitting the brakes put your head under the console and listen for a hiss. If you hear one then you have a booster malfunction. Hit the brakes, you should hear a hiss, if you do not, you probably have a bad check valve. Shut the car off, hit the pedal, you should hear a hiss, if you do not, you probably have a bad check valve. If you do not hear a hiss when you hit the brake in the morning, you have a failure of one of these parts. So to clarify, I just said exactly what these other three guys have said.
