Brake plate cover
Rockhoundrob
Car: 2009 Nissan Rogue SL
I was checking a few things (ties rods, etc...) on my daughter's 2009 Rogue and noticed the brake cover plate was badly rusted. It has a few rust holes.
I put the car back down before I realized I needed to see how the cover plates were attached.
Are they held in place by 3 bolts and easy to remove, or do I need to remove the brakes, rotor, wheel hub, etc...?
D1dad
Car: 2021 Nissan Altima SR
2018 Nissan Rogue Midnight
2009 Nissan Altima SL
I assume you mean the backing plate? It’s the whole shebang. Brakes rotors axle nut and hub. I eliminated mine when I did my 09 Altima wheel bearings many miles ago and never an issue. I figured when they stoned my country road as a cheap way to resurface it I’d pick up a stone but never did.
Rockhoundrob
If this is the case, since it has about 130,000 miles...
I might as well replace it, and also the wheel hub, rotor, etc...
Thanks for the input!
Return to “Rogue Forum”
