cdlong »
https://forums.nicoclub.com/cdlong-u11619.html
Sun Jan 22, 2006 10:14 am
here's the equation for friction. F= mu N
mu is the coefficient of friction
i had to look this up to be sure but the some of the laws of friction are... the total friction force (F) is independant of the magnitude of the area of contact and... proportional to the normal force (N).
so actual friction levels have nothing to do with contact area. (thoretically of course, and with only a 15% change, that's a reasonable assumption.) so what you quoted is right.
the only downside to the lower contact area is the heat is more concentrated, leading to earlier fade. but again, with only a 15% change; all of the pad being there; and a larger rotor to even out the heat anyway; there shouldn't be much difference there either (on the pad side, the rotor can certainly absorb more heat on it's own.)
the extra torque from the longer lever arm from the axle of the wheel to the center of the pad can either be a blessing or a curse, depending on tire choice, master cylinder, etc, etc. setup is key. you'll get better performance from a larger rotor, but only if you do it right.
