Brake pedal vibration when stopped in Drive
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
skoobahead
Car: Powder 1.8SL CVT
Has anyone had a fix or heard any info from Nissan on this issue?
I have a 2007 Versa that does NOT do this but the 2010 Versa I just purchased has a vibrating (pulsing) brake pedal when I am stopped in gear and have my foot on the pedal. You can actually hear it chattering. Putting the car in neutral will stop the vibration completely.
Thanks
Athikerguy4life
Car: 2008 Nissan Versa
eh. Its a cheap car with lots of little rattles? Mine used to always rattle when I was in drive, but it wasn't the brake pedal. It ended up being a bolt in the wheel arch. Take it to the dealership, you still have the full warranty, so they should take care of it for free, just might take forever.
skoobahead
After some self diagnosis the problem is related to very low idle in Park. The Car idles at only 600 RPM causing the vibration. Holding the brake pedal down and raising RPM to 800 completely stops vibration. Now to find out how to raise idle
Return to “Versa Technical Discussions”
