brake pedal feels stiff at startup
nabril
Car: 2015 Nissan Rogue SL
Hello guys
I park my 14 Rogue outside the garage (hers goes in it), and there's a slight incline downward.
Every time that I press the brake pedal to start the car, it feels very stiff, but once the car starts, the pedal feels nice and smooth.
Is that normal? If I recall correctly, if the car is parked at a level angle, the pedal does not feel stiff.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
It's normal. The vacuum booster bleeds out all its vacuum when the car sits overnight, which makes the pedal go high-and-hard. Once you start the car the booster gets vacuum again and the pedal returns to normal.
nabril
Thank you vstar
VStar650CL
Technical Expert
You're most welcome. Happy motoring!
Return to “Rogue Forum”
