jayturk99 wrote:.....Could the line have been cut and removed???
It's not that any line has been cut or removed. What is missing from your passenger side brakes are the sensors. It's been awhile since I looked at an intact one but IIRC the sensor wire is about 18" long. The sensor end plugs into the brake pad through the caliper. Look for about a 3/16" hole in the brake pad. If it's not there it means the PO bought pads without sensors. Not a problem.
The other end of the sensor is a 2 prong electrical connection whose location I am having a hard time remembering. Hopefully one of the experts will pinpoint it for you. If you had a sensor this is the end you would cut and splice its 2 wires together to fool the display.
Here's a few options to get rid of the BRAKE PADS WORN display. 1) Buy a pair of sensors ($20-$30?) at any auto parts store or from one of our parts sellers, cut off the connector, splice the wires together and plug them in.2) Locate the connectors on the passenger side suspension front and back, cut them off and splice the 2 wires together.3) New brake pads all around (with sensor holes) and a pair of sensors.
Personally I would go with option 1. Do a search using BRAKE PADS WORN as the search words and you'll bring up all the DIY info you need. Good luck.
