whannon »
https://forums.nicoclub.com/whannon-u69802.html
Tue Jul 03, 2007 3:49 am
1994 Q 45t 171,000 miles
I replaced the front brakes on my Q yesterday plus the front right caliper yesterday ( lower piston was hagging up a bit,, on the front right caliper ) with a rebuild caliper unit. Installed the new pads, capliper, and reinstalled the pad ware-sensor, into the rebuild caliper without incident , check all connections, etc. all appeared fine, etc.
Started the car, and the "brake Pad worn" indicated light came on in the inst cluster display, & does not reset itself.
The new pads have squeakers,, so the elec. brake pad ware indicator/sensor is not really required.
Suggestions? I did notice the few of the other posts on this topic to "wire the sensor" leads together, to disable this , warning , which is fine, any other suggestions?
I suspect its the brake sensor,, and has nothing to do with and other elect issues.
