Post by quinttheman » https://forums.nicoclub.com/quinttheman-u31204.html Sat Aug 13, 2005 5:59 am
Post by elwesso » https://forums.nicoclub.com/elwesso-u5248.html Sat Aug 13, 2005 6:03 am
Post by maxnix » https://forums.nicoclub.com/maxnix-u127.html Sat Aug 13, 2005 6:52 am
Hopefully the monitoring will result in replacing them before you hear them. Best done wiht about 20% of pad material left, and certainly with only 10% left. Depends how aggressively you use the brakes.elwesso wrote: Just remember when the pads need to be replaced (once you hear squealing)
Post by elwesso » https://forums.nicoclub.com/elwesso-u5248.html Sat Aug 13, 2005 5:08 pm
indeed... The wear limit is approx 2mm, and thats just a little thicker than a nickel.. Unless you have the piepan wheels you should be able to tell the amount of pad you have left without taking off the wheel. Otherwise, check the passenger sides because they wear faster...maxnix wrote:Hopefully the monitoring will result in replacing them before you hear them. Best done wiht about 20% of pad material left, and certainly with only 10% left. Depends how aggressively you use the brakes.
Post by quinttheman » https://forums.nicoclub.com/quinttheman-u31204.html Mon Aug 15, 2005 2:27 am
Post by DAEDALUS » https://forums.nicoclub.com/daedalus-u128.html Mon Aug 15, 2005 5:22 am
Sounds like the most obvious suspect is the worn sensor. Have it replaced.quinttheman wrote:the sensor attached looks worn but not to the point where the connection is exposed.
Post by elwesso » https://forums.nicoclub.com/elwesso-u5248.html Mon Aug 15, 2005 5:40 am
I agree its a nice system, but once you get the lightonce you always seem to have it until you bypass it..quinttheman wrote:I would like to fix the problem if possible. I really like the warning when the pads are low. But I guess if this a fault within the system I will just perform the bypass.
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
