and what about stainless steel linesnismofly wrote:dont need any special rotors or anything
axxis ultimate or something along those lines for pads, and change your brake fluid to something with higher heat capacity
hmmmf. maybe not fade, but i've heard stories of brake lines slowly melting on the inside causing the fluid properties to change. but true, that would be pressure anywaysnismofly wrote:stainless lines are for pedal feel, they really wont do anything to help fade...worthwhile still though, unless you plan a caliper upgrade later, in which case you wont need them anyway
