Brake Pads for an Infiniti QX4
JuliusJames
Car: 1999 Infiniti QX4
Hello.. I searched but couldn't find an answer to my question..
I have a 1999 infiniti QX4 and wanted to know if I can install Nissan Pathfinder brake pads instead of Infinti QX4 brake pads to my QX4?
If I can, do you know what kind of brake pads and where's the cheapest place I can buy them? I live in the Bay Area, CA.
If I can't, can you tell me why?
Thanks a lot!
Acey
Car: 96 Pathy XE
If you want cheap, just go to your local auto parts store. I don't know why you would skimp on brakes but to each their own.
Axelpkt
Car: 2002 Nissan Pathfinder 5spd
They should be the same, they are basically the same truck with different body panels. When I bought my Pathy I put on $80 ceramic pads, and 2 years later they still have at least 1/3 life left. Cheap pads means you will be most likely changing them more often.
JuliusJames
Axelpkt wrote:They should be the same, they are basically the same truck with different body panels. When I bought my Pathy I put on $80 ceramic pads, and 2 years later they still have at least 1/3 life left. Cheap pads means you will be most likely changing them more often.
Good point.. I never thought about it that way.. I think I might go ahead and buy it from Infiniti.. Thanks for the help.. U guys have been very helpful
KoukiS14
Car: 2005 Infiniti G35x
Lakeshore Slate / Stone
I bought Porterfield carbon kevlar pads for my 240sx. . lasted a very very long time. By contrast, I bought cheapies the last time, and at the time I sold it, the things were in horrendous shape. . I probably had them on there a fifth as long as the Porterfields.
My .02 -- don't skimp on the pads
Jack1944
Justy replaced the originals at about 78,000 miles, and yes they were gone... with Hawk LTS Series pads...They are very good...Especially as it's my wife's primary vehicle...
fueler
Car: 2 Nissan's
2 BMW's
I use Wagner ThermoQuiet. They (Federal-Mogul) make the OEM pads for Mercedes, BMW, Audi, and more. They are quiet, smooth, and brake hard as hell. $75 a pair
KoukiS14
speaking of hard as hell. . err . . all I'm saying is. . those look like good pads -- I'll pick some up :o
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
I've got O'Rielly Auto Parts holding a set of Wagner ThermoQuiets for me at $46. (Lifetime Wear Warranty)
I put a set of OEM Infiniti Pads on just a couple of years ago and they are gone. They were good pads though. Got 'em from Joe.
AlabamaDan
1998 Infiniti QX4
I've gone through at least two sets of front pads and the rears look like they're 75% left. Held up the new ones and compared. Amazing how they go through the front pads.
SnowSurfLax
Car: 1999.5 Infiniti QX4
2006 Infiniti M35 Sport
AlabamaDan wrote:I've gone through at least two sets of front pads and the rears look like they're 75% left. Held up the new ones and compared. Amazing how they go through the front pads.
Make sure you're setting your emergency brake everytime you park and leave it. I didn't do that on mine and smoked a pair of front brakes in 4 months. The mechanic told me my rear brakes were so out of alignment that they weren't even touching the drum.
I read in the Infiniti manual that you have to set the emergency brake everytime you park so that it will keep the rear brakes in alignment. Seems stupid to me, but that's how they did it.
I liked how Honda did it - everytime you hit the brake, it works to keep the rear drum brakes in alignment. But then, if you have discs in the back, it doesn't matter!
pathfinder_se_black
Car: 2000 pathfinder, FG2 civic si
i cant belive the brake pads cost me 80 dollars at nissan
