Thanks for the links, I'll check them out. And I live in TX. In the summer, the heat soak on your brakes can actually be felt just out running errands, let alone tracking the car. The fade can be pretty annoying. So, I don't have to track the car to want an improvement over stock, LOL... Slotted or drilled are the next logical step, but the main thing that's bugging me is how fast and bad the OEM rotors warp. Avoiding warping is my main concern, but getting some improved brake feel/bite/fade resistance is always a plus too as long as I'm upgrading...RED_DET wrote:Project MU NS pad is the pad I run on my Brembo brakes on the G. A friend of mine has been turned onto them on his Spec and he loves them. Hardly no dust and no noise. Any particular reason you want slotted and crossed drilled rotors? Do you track the car? If not, it is a waste of money IMHO.
There are plenty of sites that you can get replacement rotors/pads. Here are a few
http://www.mynismo.com
http://www.gspec.com (Talk to Greg very trustworthy)
http://www.thenismoshop.com
Thanks, Ill check this out too...FrancesTheMute wrote:http://www.stillen.com/product...ENTRA
Stillen makes rotors that work with Brembo's. I don't know about the quality though, never used em.
Not interested in OEM. They warp way too easy and are over priced. I think I'll be going with Power Slots:FrancesTheMute wrote:Front OEM:http://www.courtesyparts.com/4...=2837&
Rear OEM:http://www.courtesyparts.com/4....html
The rear I'm iffy about. Call Courtesy Parts and ask them. Great retailer in my opinion.
Yeah, I know...but I DID ask about pads in my original thread...figured it might be easier for those searching in the future if there were two threads, plus I'm hoping I get more suggestions. Didn't have much luck with the one reply I got...slim pickins all around for the Brembo package on the V. I should have just saved the money and gotten the regular brakes...*sigh*FrancesTheMute wrote:You probably should keep your threads combined into one.
Hawk, Mintex, Stillen, and of course there are OEM pads available.
http://www.stillen.com/browse....ENTRA
Wow. Thats a rip off. Thanks for the heads up...if I ever need to replace my brake lines I'll certainly be doing aftermarket...Ghost_silvia wrote:I came back from the stealership and ordered a brake line for the brembo caliper and it was $40 and the two washers and bleeding bolt was $21!!!
