Well my final update!
I was finally able to replace all the four brake rotters including brake pads of course.
After close inspection, brake calipers were fine for there age.
The sliding pins were definitely the culprits in this occasion.
This diagnosis is a good way to save some bucks if your brake pads are wearing out uneven.
Well I was able to find cheap brake rotters for around $12 bucks and the bushings for the sliding pins for $4 bucks(4pc in a box) at rockauto.com.
I tell you the bushings were really overpriced all around.I would find them by themselves over $14 bucks for one set of just two or a brake kit with parts you didn't really need for over $25 bucks.That website pretty much sells everything you need..piece by piece.
Anyway after removing the whole brake caliper assembly I used brake cleaner to remove all the old grease specially the sticky gum like film at the button of each hole.
After that I worked on the sliding pins.The rear which were giving me more issues I totally replaced with new ones from autozone for around $8 bucks a kit.
The front I reused because they weren't that bad.Cleaned them good and removed any rust with a dremel I had and finished them up with some steel wool until smooth.
I applied synthetic brake caliper grease to all pins and holes. Installed boots to pins, making sure boot was in the correct position and over the bumps on the caliper.
Pictures:
Well everything was going according to plan when the unexpected occurred!
BROKEN WHEEL BOLT!
After some research to fix this I did the following:
I bought these things
a open wheel nut ,around five large washers and some lube...all from autozone
To more easily insert the new bolt I followed this trick I saw on the web.
You first before anything; placed the new bolt in the freezer;the cold will contract the steel just a tad.
To remove the broken bolt you just have to carefully bang it out with a hammer..bang,bang,bang,bang, and its out.
Then after your ready for the installation add some lube to the area were the vertical teeth are(not on the thread) on the cold bolt and some to the hole of the wheel hub as well.
Slide the the bolt in the wheel hub and then slide a few washers over the exposing bolt(I used five).
Add the open wheel nut and slowly screw the nut in until the back of the bolt is completely through and flush against the wheel hub.
You're done!
That's all folks and many thanks to everyone's advice...until the next one!
