Brake pads and rotors...
Danrc30
Car: 93 Nissan 240SX convertible
81 Nissan 280ZX-T
85 Nissan 300ZX-T
I just put a new set of pads and rotors on my vert, and I discovered something strange. Maybe this has been covered before, but the pads it required were from a car with anti-lock brakes, but the rotors were from a car without anti-lock brakes. My car does not have ABS so what gives? Why do my calipers hold pads that are for a car with an ABS system?
Ah, the intricacies...
The verts used the larger rotors and pads from the ABS-equipped S13, likely due to the added weight.
Although I don't believe there were any verts produced with ABS.
Danrc30
81 Nissan 280ZX-T
85 Nissan 300ZX-T
But my car had the standard rotors and not the rotors from an ABS model... did I put the wrong rotors on? That's what was on my car when I took them off...
TrunkMonkey
Car: 2000 Lincoln Navigator
are you sure? there really isn't a big difference in the rotors.
-demetrius
Danrc30
81 Nissan 280ZX-T
85 Nissan 300ZX-T
The ABS rotors are 2mm thicker and a tiny bit larger in diameter. Those about the only differences I saw when comparing the two side by side and on top of each other...
Any thoughts?
I think Bart has posted on this before....
Run a search in this forum on brakes.
Danrc30
81 Nissan 280ZX-T
85 Nissan 300ZX-T
Dammit! I did that search and according to the info there I'm supposed to have abs rotors too.... now what do I do??? Is it ok to use non abs rotors?
