artandscience wrote:Both Infiniti of Scottsdale and my localdealer say that you cannot get the warning message to disappear byjust shorting the sensor leads.
That's (sorry Joe or whoever said that at Scottsdale!)
The sensor basically completes a circuit, so when it's intact the circuit is shorted. When the sensor is unplugged or worn (breaking a wire in the sensor head) the circuit is open. The ECU looks for a short to display no message, or an open circuit to show the message. You have a break somewhere in the circuit.
I always recommend not cutting the sensor wire on the harness connector side (toward the car) but instead cutting the pigtail from sensor to the harness that connects to the car (pad side). That way you can plug in a new sensor if you decided to go back with an OEM pad, as most owners eventually do. I have done this on a couple of occasions while waiting for new pads to arrive from AZ. I can't drive with those damn messages on the screen - especially at night when they won't dim with the rest of the dash!
Heath
